Wpincumbe
Apr 05, 2023Follower
R6700v3 Port forward
I have recently install a server inside my home network. I am able to connect to the server from any machine,(PC ..Smart phone) as long as they are inside the home network. I have also tried to access the server by using the DDNS address , again as long as inside the home network i can reach the server. I have turned on port fowarding for HTTP :80 , I have factory reset the R6700 and started all over. all to no sucess.
I can Ping my router from out side by using the ISP assigned address, and get the correct responce. any suggestions.
1 Reply
- KitsapMaster
Wpincumbe wrote:I have recently install a server inside my home network. I am able to connect to the server from any machine,(PC ..Smart phone) as long as they are inside the home network. I have also tried to access the server by using the DDNS address , again as long as inside the home network i can reach the server. I have turned on port fowarding for HTTP :80 , I have factory reset the R6700 and started all over. all to no sucess.
Difficult to tell for sure what you are trying to do.
A server for what?
No success at what?
