Cinc
Nov 17, 2020Aspirant
r6700v3 randomly loses internet over ethernet only
For a few months now I will randomly lose my internet just over the ethernet connection and not wifi. My computer that is wired to the router will drop connection but my phone will maintain internet ...
Nov 17, 2020Guru - Experienced User
have you tried replacing the cable?
Do any other wired devices have issues?
Cinc
I have tried a different ethernet cable. My computer is the only thing directly wired to the router.
- plemansNov 17, 2020Guru - Experienced User
Try a different port on the router?
You have anything else you can hardwire in?
It tough to say 100% when its only 1 device having issues. I understand you rebuilt it but it wouldn't be the first time of something having an issue with a windows 10 build.
- CincNov 17, 2020Aspirant
I have tried different ports. I can probably borrow an old laptop from someone as I don't have one myself and plug it in to see if it drops connection when my computer does.
