Neshkar
Oct 15, 2021Tutor
R6700v3 reset loop and cant log into wifi
Tried resetting the router via the manual instructions and forums (30/30/30 though I did that one last for "safty") After trying, I noticed that the WiFi never changed and was still protected. I tr...
- Oct 16, 2021
Have you tried hardwiring into the router?
Then you can access it and set it up with your own ssid/password
Neshkar
Oct 15, 2021Tutor
Update: obviously the reset button for 7 seconds ain't working. The 30/30/30 puts the router in recovery loop and I have to hit the reset with power on just to fix that.
Still no luck on logging into wifi to even try connecting to the IP.
