Neshkar
Oct 15, 2021Tutor
R6700v3 reset loop and cant log into wifi
Tried resetting the router via the manual instructions and forums (30/30/30 though I did that one last for "safty") After trying, I noticed that the WiFi never changed and was still protected. I tr...
- Oct 16, 2021
Have you tried hardwiring into the router?
Then you can access it and set it up with your own ssid/password
Oct 16, 2021Guru - Experienced User
Neshkar
Oct 16, 2021Tutor
... aw man I feel like an idiot xD
Updating firmware now! Thanks! Guess I was working to late and not thinking straight. Thanks! I'll buy you a virtual drink xD
