Neshkar
Oct 15, 2021Tutor
R6700v3 reset loop and cant log into wifi
Tried resetting the router via the manual instructions and forums (30/30/30 though I did that one last for "safty") After trying, I noticed that the WiFi never changed and was still protected. I tr...
- Oct 16, 2021
Have you tried hardwiring into the router?
Then you can access it and set it up with your own ssid/password
Oct 16, 2021Guru - Experienced User
michaelkenward
That is much better than fiddling around with phones.
Reading the the manual might also help.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
You may have done that already. I can't tell from the first message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
