TristanX
Jan 18, 2022Guide
R6700v3 Slow Speeds
I am gettin REALLY slow speeds since the last firmware update. Iam currently on firmware V1.0.4.122_10.0.95. Any help would be appreciated.
I'd start with a factory reset and reinstall. Don't use a backup.
If that doesn't help, then I'd try downgrading the firmware a version.
I have the same issue. R6700v3 V1.0.4.122_10.0.95. I pay for 750mbps and only get 250mbps download max with this router. I tried reinstall firmware, tried factor reset. Tried removing power to everything and powering everything back up (with time delays) in proper order from modem, router, to computer. Still no luck. I know the modem is good because I have another older router that atually gets 750mbps. Also tried disabling QoS (disabled by default), turn off Access Controls (disabled by default), Turn off Traffic Meter (disabled by default). I am at a loss. Very frustrated with this router now. Loved it, now hate it.
Any other ideas out there?
I can go back firmwares until the issues goes away (if it does). Haven't tried that yet. But it is a huge time waste.
What is interesting, is if it is set as an Access Point it actually gets the 750mbps! But when it is in router mode it does not.
What is that modem?
