Phosphonothioic's avatar
Jan 23, 2023
R6700v3 Teoubleshooting
Modem: Motorola MB8600
Router: Netgear R6700v3
ISP: Spectrum
As it stands, the ISP can see the new modem I set up and claim they are having no issues communicating with it.
The internet indicator on the router is flashing white (as it should?), but I can't get internet through either a LAN connection nor wireless. I have tried the setup wizard both through the router itself and the Nighthawk app. The router wizard just can't find the internet and asks me if I want to try again. The nighthawk app can't connect either, and something strange is happening.
The app has been connected to the router wirelessly through my phone(Pixel 3A of it matters), but I'm forced to "sign-in" (wireless settings menu on the phone) to the SSID which redirects me to the Spectrum modem activation page that I've already gone through. Then I have to select to use that network in the app for it to work. But, even after all that, I can't reach the internet aside from Spectrum's activation page.
Also, to note, I did a full reset of the router just to make sure it was a clean install with the modem.
At my wits end here...
  • plemans's avatar
    Jan 23, 2023
    reboot the modem and your computer. have the modem boot up for a couple minutes and then power up the computer.
    See if that gets it connected. Just have to ensure the MB8600 is working correctly first before we start troubleshooting the router.
  • plemans's avatar
    Hardwire a pc/laptop directly into the modem and see if its actually activated. That activation page shouldn't come up if its already activated.
    • Phosphonothioic's avatar
      Phosphonothioic
      I connected the modem to the 1G port on my motherboard. I figured that had to be the correct port (vs. the 2.5G) because it had 600+GB of traffic in the last month.
      It's coming up as an unidentified network. The troubleshooter is telling me that it doesn't have a "valid IP configuration."
      IP assignment is set to DHCP.
      • plemans's avatar
