JohnyVindex's avatar
JohnyVindex
R6700v3 unable to support 400Mbps - capped at 140Mbps
My R6700v3 seems to have the internet downlink capped at around 140Mbps.  I upgraded to 400 Mbps service but was unable to get the connection speeds.  A tecnician from the ISP came to take a look and...
  • A_ALI's avatar
    A_ALI
    Aug 06, 2019
    I couldn't wait anymore, kicked the family off the internet...and...Success!!!  After a factory reset, and a little waiting, I'm still on Firmware version V1.0.3.66_10.0.50, and using Speedtest my download speed is 947Mbps!  This is great!  Going to test my other wired devices to make sure all is good there, and then I'm done for now!
    I'm hoping that Netgear sees this post, and start looking into a fix to resolve the issue with the new firmware.  I'd love to be back on the newest firmware version.
