AdamB920
Feb 07, 2021Aspirant
R6700v3 UPnP/Teredo, Issues with NAT
My Nighthawk R6700v3 router has been having consistent issues connecting to multiplayer services, especially with a wired connection. On a daily basis each of my ethernet port lights will turn amber,...
AdamB920
I downloaded the 1.0.3.66 firmware which was still bringing up the same issues. I went ahead and did the factory reset and cleaned all memory via the router webpage. Reinstalled 1.0.3.66. I was then getting messages of double NAT type found. I’ve remained on the 1.0.3.66 firmware and haven’t upgraded back. I’ve been having issues each time I’ve restarted the router with the second light (internet light) turning back on despite all cables being connected. All wired connection ports remain lit up amber
Feb 07, 2021Guru - Experienced User
You said your apartment provides the isp?
If you put the netgear router in ap mode, does it work?
- AdamB920Feb 07, 2021AspirantYes, my apartment provides the internet. I’ve tried twice to put it in ap mode to remedy the double NAT type and each type while restarting the router was unable to identify my internet for about 5 minutes. The second light (internet light) wouldn’t turn on and I’d lose connection while trying to update the router and I’d ultimately have to reset the router.
- plemansFeb 07, 2021Guru - Experienced User
Did you check with the apartments ISP/setup?
- AdamB920Feb 07, 2021AspirantI’ve asked if they’re having any issues or any other reports of outages and they’ve said there’s been no complaints. I’m not sure what I’d be looking to check on with the setup, but I can give it a try
