Magek
Oct 12, 2024Follower
R6700v3 went to reset now makes weird noise and lights aren’t on
So more detail went to reset cause the wifi went out and when I went to plug it back in it started whirring noises slightly as I plugged it in then when turned on got louder lights flash I tally when ...
Oct 12, 2024Guru - Experienced User
Try a different power adapter?
Try 30-30-30 reset on the router?
If this fails, time to get something new.
