dpmoore
Feb 11, 2022Star
R6700v3 Wired Connection ~200Mbps
I bought this router in January 2021. After I set it up, the wired speeds tested out at ~800Mbps. So, I know it was working as expected and that was before I upgraded to the 1200Mbps package. I re...
- Feb 11, 2022
FURRYe38 wrote:Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
No. I will try that before the factory reset though. Thanks
Has a factory reset and setup from scratch been performed since last FW update? No.Will try tonight
If any of these suggestions don't seem to help, you may need to revert back FW to what had been working.
That is non-starter for me due to security concerns. Unit is defective if I cannot maintain max speeds with latest FW
Feb 11, 2022Guru - Experienced User
- dpmooreFeb 11, 2022Star
