dpmoore
Feb 11, 2022Star
R6700v3 Wired Connection ~200Mbps
I bought this router in January 2021. After I set it up, the wired speeds tested out at ~800Mbps. So, I know it was working as expected and that was before I upgraded to the 1200Mbps package. I re...
- Feb 11, 2022
FURRYe38 wrote:Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
No. I will try that before the factory reset though. Thanks
Has a factory reset and setup from scratch been performed since last FW update? No.Will try tonight
If any of these suggestions don't seem to help, you may need to revert back FW to what had been working.
That is non-starter for me due to security concerns. Unit is defective if I cannot maintain max speeds with latest FW
Feb 11, 2022Guru - Experienced User
Have you tried a factory reset and then tested speeds with the router in the default configuration?
Reason I ask is the R6700 uses cut through forwarding to hit gigabit speeds.
The access control, traffic monitoring, qos, parental controls all disable it. And even after disabling those services, I've seen ctf not get re-enabled. So speeds stay slow.
So try a factory reset and test the speeds with the router in its default configuration. If it test full speeds, then start setting up your services with testing the speeds each time you change something.
dpmoore
Feb 11, 2022Star
I have never enabled access control, traffic monitoring, qos, parental controls. I think the only thing I changed in the setup was to disable the Guest networks.
I have not tried a factory reset. That would be my last resort which seems I am there. I presume that will keep the latest Firmware version intact?
I will try the factory reset later tonight (have to work) and report back.
Thanks
- plemansFeb 11, 2022Guru - Experienced User
It'll keep the current version of firmware intact.
It only removes settings.
If that doesn't work, then we can try other versions of firmware.
Also, try enabling ipv6 on the router if it initially tests low.
What site/app are you using to speedtest with?
And what device?
- dpmooreFeb 11, 2022Star
I will add ipv6 to my troubleshooting list.
I have always used speedtest.net. I have tested using Lenovo T14 laptop and an older Dell Desktop. Both have 1Gb ethernet controllers
