RL-SanRAmon
Dec 10, 2022Tutor
R6700V3 with firmware V1.0.4.128 WiFi issues
Recently updated to V1.0.4.128 and have had issues with connections lost to the 2.4Ghz WiFi and also the 2.4Ghz WiFi slowing to a crawl. Reboot fixed it each time, but very annoying. Wired connection...
- Dec 30, 2022
Problem has been resolved by disabling WMM (Wi-Fi multimedia) for 2.4GHz b/g/n. This has the downside that some wireless clients, especially Intel chip based, will slow the connection to 54Mbps. Luckily, my 5Ghz Wi-Fi didn't have an issue, so WMM for 5GHz was left enabled.
I've seen other posts about Netgear's WMM feature causing serious issues, but it didn't cause problems for me until the resent firmware update. If anyone from Netgear looks at these messages, I hope WMM gets fixed.
Dec 10, 2022Guru - Experienced User
Before downgrading, try a factory reset. Sometimes old settings can cause issues and doing a reset and reinstalling without using a backup can help.
