cats2000
Oct 22, 2021Aspirant
r6700v3 won't broadcast 5ghz
I don't know TOO MUCH about this stuff so I'll try to include all the info I can on the router and what not. I have tried to reset,reboot,erase,go back to older FW, and also reset my modem and di...
Oct 22, 2021Guru - Experienced User
After you reset the router, did you set up the router for separate wifi SSID names and give a unique 5Ghz SSID name to be seen on a mobile device?
cats2000
I left it with it's "-5g" name, but i'll set up and change the names now to see what happens.
Also as FYI the modem I'm using is the NETGEAR cm600
- FURRYe38Oct 22, 2021Guru - Experienced User
K,
You might also disable the 2.4Ghz radio as well on the Router and see if this does anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Check with multiple devices to see if anyone of them sees the 5Ghz SSID name.
