GMatwins3
Sep 03, 2022Aspirant
R6700v3 won't update and frequently loses wifi
I have tried many times without success to update firmware using the Nighthawk Netgear App. It fails every time. My present firmware is V1.0.4.106. Also, I frequently lose internet connection. Help ...
Sep 03, 2022Guru - Experienced User
Have you tried manually updating using a pc/laptop?
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
also, when you loose connection, is it to all devices? Just a specific device? Just wireless devices?
What actual error does it give you? Does it say, "connected, no internet", does it not see wifi at all? What actually happens?
What modem/gateway is it connected to?
What fixes the issue?
- GMatwins3Sep 03, 2022Aspirant
The error message states "There was a problem checking firmware update". No I haven't tried manually.
The connection issues are mainly with cell phones and ipad. It will bbe working. Then at intermittent times, an app with stop working and a message stating, "wifi not working, do I want to turn on celluar data". When this happens I turn wifi off then back on from device and it temporarily corrects problems. Laptops are often slow but not always.
I have BLAST speed wifi, and router is centrally located close to all devices. Motorola modem
Thank you
- plemansSep 03, 2022Guru - Experienced User
1. what motorola modem?
2. it happens only to wireless devices?
3. when you get that message, is it still connected to the wifi? Or does it self disconnect and you're just disabling the wireless on your device then re-enabling
4. Does it happen to all devices?
- GMatwins3Sep 12, 2022Aspirant
First, thank you for continuing to try to help me. I'm sorry I haven't responded in a bit. I haven't been well and very hard to concentrate.
1. Modem - Model MB7621 / DOCSIS 3.0 with 24x8 channel bonding
2. Mostly wireless devices have the problem
3. When I go to "wireless settings", I have not noticed it actually not connected to wifi. Sites or apps will stop working or start spinning as it does when wireless connection is lost. Also, FaceTime freezes or drags. This doesn't happen when same devices are used at another home.
4.It happens on 2 cell phones and an ipad. My laptop is slow, but it is three or four years old
Does this tell you want you are asking? Thank you so much.
