Kardano
Oct 05, 2022Luminary
R6800 MAC adress
Hello, i hav one problem with my R6800 router. Router is changing LAN MAC adress after every reboot. If i use button "reboot" on router information, after reboot router has new LAN MAC adress. ...
Oct 05, 2022Guru - Experienced User
Is it running in AP mode?
if so, you should be able to set it with a static ip address on whatever is handling dhcp
- KardanoOct 05, 2022Luminary
Hello,
it is running s Router. DHCP is ON and working.
And for all my life in IT (30years+) is this 1st router that is changing its own LAN MAC adress on every boot.......
- plemansOct 05, 2022Guru - Experienced User
What lan mac address? Where are you seeing that?
Just checking for clarity
