Kardano
Oct 05, 2022Luminary
R6800 MAC adress
Hello, i hav one problem with my R6800 router. Router is changing LAN MAC adress after every reboot. If i use button "reboot" on router information, after reboot router has new LAN MAC adress. ...
Kardano
Hello,
it is running s Router. DHCP is ON and working.
And for all my life in IT (30years+) is this 1st router that is changing its own LAN MAC adress on every boot.......
Oct 05, 2022Guru - Experienced User
What lan mac address? Where are you seeing that?
Just checking for clarity
- KardanoOct 05, 2022Luminary
Hello plemans
I am using Wake me on Lan for checking what is actual MAC adress (it is the same as on advanced settings) Adding Pictures of actual mac and "todays old macs"
Router is on own lan with one VM machine only. For testing. When i press "Reboot" button, Mac adres is changed in boot process.
- plemansOct 05, 2022Guru - Experienced User
Not really paid that much attention to it before but my understanding was it was a static address as well.
