TeamMM3
Jul 03, 2022Aspirant
R6850 Discord Voice Cutting out Randomly
I just moved and with that move came the purchase of an R6850 router. I've had it hooked up a few days ago and ever since have been having issues with discord. Prior to this router I was using the sa...
Jul 03, 2022Guru - Experienced User
What devices are you using with Discord?
Wireless or Wired when using Discord?
Happens on both Wireless and Wired?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
TeamMM3
Firmware Version: V1.1.0.88_1.0.1
Modem: Hitron Technologies EN2251
I'm using my PC which is wireless at the moment using the 5G. The channel on 5G is 153 and on 2G (which I have no tried) is set to Auto. I'm not picking up an other Wifi from any neighbors. Will first try switching the channel to Auto and if that doesn't work will try going wired and see if the results remain the same.
