PBrown1962
Oct 05, 2021Follower
R6850 laptop working i pad says no internet how do i fix this
1 Reply
IF the laptop is working then you might contact Apple support for the ipad since it's not working.
make sure your ipad is connecting to the routers SSID name and password.
Forget the SSID name on the ipad and try to reconnect to it.
