mluvw47
Mar 04, 2017Aspirant
R6900 after firmware updated, no internet connection after doing checking firmware updated again
I updated my R6900 router to the latest verison ( R6900, Version 1.0.1.16) After that, the router get rebooted and I am able to get internet connection and the connected device working fine. Then ...
- Mar 14, 2017
mluvw47 wrote:
Not sure about ISP block anything like that I am aware of it, since it is In my case, I can do manual down the zip and perform update without any issue.:cathappy:
Comcast used to do DNS redirects, but I am not sure they are doing them now.
You can test it by reconfiguring your router temporarily to use 8.8.8.8 as the DNS server (instead of the comcast-supplied DNS). That's google's DNS server.
schumaku
Mar 06, 2017Guru - Experienced User
mluvw47 - the message might be misleading, however there are multiple reports in the community that various router models have not got firmware upgrade notifications the last weeks.
Can't say more - most Nightawks get firmware updates (Beta or bugfix before the stuff is on the live feed) - lack of experience.
- mluvw47Mar 06, 2017Aspirant
Hi, @schumaku
IMHO, it is indeed confusioning and misleading. Someone should create a bug on this matter, 'coz there is no way do firmware update from the router anymore. Need to save all the settting(in a file), like michaelkenward mentions and then factory reset and restore it back.(And hopefully after that Check firmware update would work again, not to show this confusing message).
For the record, this is what I have done.
Step 1. stable v1.4 firmware update to v1.6 (beta) -- work fine thru the router.
Step 2. from v1.6 (beta) checking firmware, gettin that above misleading message.
Step 3. manual download back to 1.4v, it still getting this above misleading message.
Thanks,
Matt
PS: schumaku Thumb up to u. Thnx
