mluvw47
Mar 04, 2017Aspirant
R6900 after firmware updated, no internet connection after doing checking firmware updated again
I updated my R6900 router to the latest verison ( R6900, Version 1.0.1.16) After that, the router get rebooted and I am able to get internet connection and the connected device working fine. Then ...
- Mar 14, 2017
mluvw47 wrote:
Not sure about ISP block anything like that I am aware of it, since it is In my case, I can do manual down the zip and perform update without any issue.:cathappy:
Comcast used to do DNS redirects, but I am not sure they are doing them now.
You can test it by reconfiguring your router temporarily to use 8.8.8.8 as the DNS server (instead of the comcast-supplied DNS). That's google's DNS server.
mluvw47
Mar 06, 2017Aspirant
Thanks. It is just interesting that need to do it. I would expect the firmware update will not cause this kind of akward issue.
michaelkenward
Mar 06, 2017Guru - Experienced User
mluvw47 wrote:Thanks. It is just interesting that need to do it. I would expect the firmware update will not cause this kind of akward issue.
It doesn't always.
If it is just a security fix, then there won't be many other changes.
The reset is more important if Netgear adds new features to a device. These may not be compatible with the old settings.
No one forces anyone to update their firmware. If you don't want the new features, or they aren't relevant for you, just ignore the update.
Even security updates are mostly theoretical. I'vc seen no reports of real exploitation of the latest scare. It is just something that someone cooked up in a lab.
My line is not to reset unless I have to. If the thing works after the flash, leave it alone.
