mluvw47
Mar 04, 2017Aspirant
R6900 after firmware updated, no internet connection after doing checking firmware updated again
I updated my R6900 router to the latest verison ( R6900, Version 1.0.1.16) After that, the router get rebooted and I am able to get internet connection and the connected device working fine. Then ...
- Mar 14, 2017
mluvw47 wrote:
Not sure about ISP block anything like that I am aware of it, since it is In my case, I can do manual down the zip and perform update without any issue.:cathappy:
Comcast used to do DNS redirects, but I am not sure they are doing them now.
You can test it by reconfiguring your router temporarily to use 8.8.8.8 as the DNS server (instead of the comcast-supplied DNS). That's google's DNS server.
iodie
Mar 15, 2017Aspirant
I am also a Comcast subscriber so that is likely the connection, having said that oddly without making the DNS change on the router it started working again today (or at least reporting no new firmware instead of the previous message).
michaelkenward
Mar 15, 2017Guru - Experienced User
Perhaps it has taken time for the Netgear address to roll out to the world's DNS system.
