mluvw47's avatar
mluvw47
R6900 after firmware updated, no internet connection after doing checking firmware updated again
I updated my R6900 router to the latest verison ( R6900, Version 1.0.1.16) After that, the router get rebooted and I am able to get internet connection and the connected device working fine.  Then ...
  • StephenB's avatar
    Mar 14, 2017
    mluvw47 wrote:
    Not sure about ISP block anything like that I am aware of it,  since it is In my case, I can do manual down the zip and perform update without any issue.:cathappy:
    Comcast used to do DNS redirects, but I am not sure they are doing them now.
    You can test it by reconfiguring your router temporarily to use 8.8.8.8 as the DNS server (instead of the comcast-supplied DNS).  That's google's DNS server.
