mluvw47
Mar 04, 2017Aspirant
R6900 after firmware updated, no internet connection after doing checking firmware updated again
I updated my R6900 router to the latest verison ( R6900, Version 1.0.1.16) After that, the router get rebooted and I am able to get internet connection and the connected device working fine. Then ...
- Mar 14, 2017
mluvw47 wrote:
Not sure about ISP block anything like that I am aware of it, since it is In my case, I can do manual down the zip and perform update without any issue.:cathappy:
Comcast used to do DNS redirects, but I am not sure they are doing them now.
You can test it by reconfiguring your router temporarily to use 8.8.8.8 as the DNS server (instead of the comcast-supplied DNS). That's google's DNS server.
mluvw47
Mar 15, 2017Aspirant
That doesn't seems in my case.
On my router, I changed it back the DNS "Get Automatically from ISP", then apply the change.
Did a firmware update, it shows that message again. The only way to get check firmware update work is use Primary DNS as 8.8.8.8
Mar 16, 2017Guru - Experienced User
You can also set your secondary server to 8.8.8.4.4 if you wish (another google server). Or set it to the comcast server.
