Yohimbe
Jun 13, 2017Aspirant
R6900 extremely slow download speeds
The problem I am having is extremely slow download speeds. I pay for verizon 75/75 and I have a quantum router. I set up the netgear router as acess point to provide wifi to a part of the house that'...
- Jun 13, 2017
Check the link speed between the quantum and 6900. If the link speed is dropping, then it sounds like a cable issue, irregardless if it works with the laptop. You can also try moving the the Ethernet cable on the 6900 from the WAN to the LAN port, and re-test..
