Maloha
Oct 13, 2016Star
R6900 Nighthawk AC1900 - 5ghz drops every day
Hi, I have the Costco router AC1900 R6900. Setup was smooth, however, the 5ghz network drops every day and I have to reboot the router. The network is visible, just won't connect without a reboot...
- Jul 27, 2017
Hi Guppy,
Try to reset the router to factory default. If same thing, I would suggest contacting support team.
JamesGL
Oct 13, 2016NETGEAR Employee Retired
Hi Maloha,
1. What is the firmware version of the router?
2. Have you tried to reset the router to factory default and reconfigure?
JamesGL
Community Team
Maloha
Oct 13, 2016Star
Hi James,
Firmware Version
V1.0.0.4_1.0.10
Which I understand is the latest version.
Via a chat session with support we reset everything back to factory defaults. It miraculously started working for 3 days before doing any reflashing, then the same problem resurfaced. My devices see the network, but I get "incorrect password" and "cannot connect to this network". When I reboot, it connects.
- MalohaOct 15, 2016Star
As an update, I bought a 2nd R6900 yesterday and installed it this morinng. I'm having the EXACT same issue - I have to reboot the router in order to connect to the 5ghz network.
If I disconnect all devices from 5G, they will not reconnect without a reboot. I get a "wrong password" or "cannot connect to this nework" errors. If I leave one device connected, the network stays available.
For now, I'm going to keep the 2nd router, return the first Netgear, and live with the reboot situation. I even bought a Linksys 1900ac to try it out - the network stayed available without dropping, but the connection speeds were awful so I returned it.
- JamesGLOct 19, 2016NETGEAR Employee Retired
Hi Maloha,
Can you try to load the previous firmware then check if the same problem. Reset after loading the firmware.
http://kb.netgear.com/app/answers/detail/a_id/29920?cid=wmt_netgear_organic
JamesGL
Community Team- MalohaOct 20, 2016Star
I may try it this weekend if I have time. Currently, like I mentioned, the network stays available as long as at least one device stays connected 24/7.
