Maloha
Oct 13, 2016Star
R6900 Nighthawk AC1900 - 5ghz drops every day
Hi, I have the Costco router AC1900 R6900. Setup was smooth, however, the 5ghz network drops every day and I have to reboot the router. The network is visible, just won't connect without a reboot...
- Jul 27, 2017
Hi Guppy,
Try to reset the router to factory default. If same thing, I would suggest contacting support team.
Damador490
Dec 03, 2016Tutor
I am having the same problem as Maloha. My internet speed will decrease as the day goes along. It is normally around 25mbps and will drop down to two or three and I won't be able to connect to 5g. Sometimes it shows but keeps asking for a password and then says wrong password. Other times you can't even see the 5g and the 2.4 is very slow. I do a reboot and everything works again. I have to reboot several times a day. I just bought the unit at Costco this week.
