Maloha
Oct 13, 2016Star
R6900 Nighthawk AC1900 - 5ghz drops every day
Hi, I have the Costco router AC1900 R6900. Setup was smooth, however, the 5ghz network drops every day and I have to reboot the router. The network is visible, just won't connect without a reboot...
- Jul 27, 2017
Hi Guppy,
Try to reset the router to factory default. If same thing, I would suggest contacting support team.
Maloha
Mar 04, 2017Star
I ended up keeping mine. It rarely drops the 5ghz signal now. Probably because I keep one device connected at home all the time. Haven't done the firmware update only because I'm afraid new problems will surface.
LeeH
Mar 05, 2017Prodigy
You might be having a DHCP problem. Have you tried reserving IP addresses in the router?
