Maloha's avatar
Maloha
Star
Oct 13, 2016
R6900 Nighthawk AC1900 - 5ghz drops every day
Hi,   I have the Costco router AC1900 R6900. Setup was smooth, however, the 5ghz network drops every day and I have to reboot the router. The network is visible, just won't connect without a reboot...
  • JamesGL's avatar
    JamesGL
    Jul 27, 2017
    Hi Guppy,
    Try to reset the router to factory default. If same thing, I would suggest contacting support team.
