rkinhyd76
Aug 20, 2017Aspirant
R6900 Nighthawk setup wizard disabled
I used Nighthawk R6900 in the USA for a while. Everything worked fine. Now i am using same router in India for ACT ISP. To configre PPPoE, option 'Internet setup wizard' is disabled. I need this opti...
- Aug 22, 2017
Hi rkinhyd76,
Make sure the router is not setup as an access point.
Check this KB below. Uncheck the "Enable AP mode".
JamesGL
Aug 21, 2017NETGEAR Employee Retired
Hi rkinhyd76,
How is the device connected to the modem?
Try this article.
rkinhyd76
Aug 22, 2017Aspirant
Thanks for suggestions. I am not using modem. From the wall point, i am directly connecting to router and using WiFi. I tried to follow the steps as per link, at
"STEP 3. Under the Basic Tab, click on the Internet." Internet hyperlink is disabled. Please suggest. Thanks in advance.
