rkinhyd76
Aug 20, 2017Aspirant
R6900 Nighthawk setup wizard disabled
I used Nighthawk R6900 in the USA for a while. Everything worked fine. Now i am using same router in India for ACT ISP. To configre PPPoE, option 'Internet setup wizard' is disabled. I need this opti...
- Aug 22, 2017
Hi rkinhyd76,
Make sure the router is not setup as an access point.
Check this KB below. Uncheck the "Enable AP mode".
