gramps74
Apr 01, 2021Aspirant
R6900 nighthawk
So i got it off facebook no cd downloaded app to phone got that working but nothing else works no connection. Old 7 Laptop and roku tv
gramps74
Ok so found smartswitch in app that fixed tv but no go on laptop maybe it is 2.4? Then what?
michaelkenward
Apr 02, 2021Guru - Experienced User
I don't understand any of those messages.
Take this one:
Smartswitch? App? TV? Laptop?
Are you trying to set up a second hand R6900? Do you have problems with it? If so what are they?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
You may have done this already. I can't tell from your message.
- gramps74Apr 02, 2021AspirantSorry if you were confused you did interpret correctly and i did solve my problem although i find the app and other help are written by/for savvy enthusiasts not beginners
