Deltahulk
Jul 27, 2017Aspirant
R6900 Seems to block certain web sites for no reason
Nighthawk R6900 Firmware Version V1.0.1.22_1.0.18 (Latest Version) Windows 10 Home Version 1703 Samsung Galaxy S8 Recently I had problem accessing Craigslist.org and then later iomoio.com . At first I...
- Aug 09, 2017
Hi Deltahulk,
Try changing the MTU size of the router.
https://kb.netgear.com/25675/How-do-I-change-the-MTU-size-on-my-NETGEAR-Wireless-Router-DSL-Gateway
SystemCrash
Jul 27, 2017Guide
Are you using any custom DNS servers? If not, try using 8.8.8.8 or 8.8.4.4 (Google DNS servers) as a DNS server.
- DeltahulkAug 04, 2017Aspirant
I changed the DNS servers and it seems to have helped with Craigslist. However, iomoio.com always times out when going through the router. When connected directly to the modem I have no problem logging on or if I logon through the hotspot connection on my Samsung S8 with Verizon there aren't any problems. So at this point 1/2 of my problem is solved.
Truly, I do appreciate the help you provided.
- JamesGLAug 09, 2017NETGEAR Employee Retired
Hi Deltahulk,
- JamesGLAug 13, 2017NETGEAR Employee Retired
Hi Deltahulk,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
