Riley78
Mar 17, 2022Guide
R6900 speed
What is the max wired download speed will this support? (this is not the version 2 or 6900P)
- Mar 17, 2022
Thanks for the reply.
I am thinking of moving to a higher speed tier and wondered if a new router would be needed. The link to the R7000 showed a
speed test result of 950 Mbps which exceeds my needs.
Mar 17, 2022Guru - Experienced User
SInce it has 1Gb WAN and LAN ports:
https://www.netgear.com/images/datasheet/networking/wifirouter/R6900.pdf
It has the potential to support near 900Mbps WAN to LAN speed.
May depend on if it has HW NAT acceleration or cut thru support.
May depend on ISP modem/ONT services as well.
The R7000 can:
Something you can check to see yourself:
https://www.duckware.com/tech/wifi-in-the-us.html#speedtest
- Riley78Mar 17, 2022Guide
- FURRYe38Mar 18, 2022Guru - Experienced User
The R6900 should be able to handle your needs then...
