Riley78
Mar 17, 2022Guide
R6900 speed
What is the max wired download speed will this support? (this is not the version 2 or 6900P)
- Mar 17, 2022
Thanks for the reply.
I am thinking of moving to a higher speed tier and wondered if a new router would be needed. The link to the R7000 showed a
speed test result of 950 Mbps which exceeds my needs.
Riley78
Mar 17, 2022Guide
Mar 18, 2022Guru - Experienced User
The R6900 should be able to handle your needs then...
