mdeschler33's avatar
mdeschler33
Follower
Aug 24, 2022
R6900 V2
Updated the newest firmware and now after reboot blinks a white light
  • michaelkenward's avatar
    michaelkenward
    Which light? There are six or more on the front of the R6900v2.
    Does the router work?
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Check the section in the manual Troubleshoot With the LEDs.
  • plemans's avatar
    What firmware did you install?
    Like michaelkenward says, what light is the one blinking? Theres several on there and each mean different things?
    Is it working?
    Did you try a factory reset (if you have issues)? Its usually the first place we start if there's issues after changing firmware.
