rayr6900
Apr 27, 2018Aspirant
R6900 wifi switch / button
I pressed the wifi switch on the top of the Nighthawk R6900. Pressing it again does not activate wifi again. Is there a sequence I need to follow to activate wifi?
- May 01, 2018
I actually had to power the router off and hold the wifi switch when powered back on. Wifi did not return until I depressed the wifi switch again.
Thanks to the community for your assistance.
michaelkenward
Apr 28, 2018Guru - Experienced User
Go into the control interface and try turning it on there.
There is support stuff for the R6900 at the end of this link:
>>> R6900 | Product | Support | NETGEAR <<<
See page 170.
Or use the desktop genie.
