nagsathya
Apr 20, 2020Aspirant
R6900
I setup AC 1900(R6900) as wifi router using xifnity wifi router modem. After that I bought new netgear xifity modem/router to replace my xifinity modem . Now I am not able to reset my AC 1900 (R690...
- Apr 25, 2020
nagsathya wrote:
The issue is I am not able to reset the my admin password for my Netgear Nighthawk R6900 using router login. If I am able to do this I can use my Netgear Nighthawk R6900 router as an extended wifi router for my second floor. The issue is whenver I try to login my netgear roguter login page it picks up only my first floor modem/router one. How to resolve this?
You have two routers on your network. The unnamed xfinity wifi modem router and the R6900.
That arrangement means that you cannot use things like routerlogin.net to get into the controls.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
You have already been offered ways around the issue. Essentially, put the R6900 into AP mode or bridge the modem/router.Both suggestions need a wired connection between the modem/router and the R6900.
In other words, investigate how these things work and come up with a strategy that will do what you want.
I'm afraid that it is highly unlikely that someone will come up with a solution that gets things to work as they are now.
microchip8
Apr 20, 2020Master
You need to set the NETGEAR xfiniti modem/router in bridge mode and let the R6900 do the work
nagsathya
Apr 25, 2020Aspirant
I have a two floor house. In the first floor I am using NETGEAR MODEM/ROUTER( XFINITIY COMPATIABLE ONE). I want to use this router for first floor. I have another spare Netgear nighthawk R6900 to use for second floor. The issue is I am not able to reset the my admin password for my Netgear Nighthawk R6900 using router login. If I am able to do this I can use my Netgear Nighthawk R6900 router as an extended wifi router for my second floor. The issue is whenver I try to login my netgear roguter login page it picks up only my first floor modem/router one. How to resolve this?
NOTE: Router login page is not recoganizing the Netgear Nighthawk R6900 using serial number to rest the password
- michaelkenwardApr 25, 2020Guru - Experienced User
- nagsathyaApr 26, 2020Aspirant
AP mode resolved my issue. Thanks for the solution
