lancewo
Apr 28, 2022Guide
R6900
My R6900 Router resets the date Sep 8, 2021 every time I power off my modem. I'm setting up this Router as an access point. I used to be able to run the firmware update and it would correct the dat...
Apr 29, 2022Guru - Experienced User
Have you tried simply changing your ntp time server info? That way it potentially syncs on the reboot?
