lancewo
Apr 29, 2022Guide
R6900
My R6900 Router resets the date Sep 8, 2021 every time I power off my modem. I'm setting up this Router as an access point. I used to be able to run the firmware update and it would correct the dat...
Apr 29, 2022Guru - Experienced User
Have you tried simply changing your ntp time server info? That way it potentially syncs on the reboot?
lancewo
Apr 29, 2022Guide
Hi,
Could you show me how to do that? what is ntp?
I am currently using an xfinity cable modem and I'm setting my netgear as an access point to that I could connect to my Readshare external disk drive.
Thanks so much
