lancewo
Apr 28, 2022Guide
R6900
My R6900 Router resets the date Sep 8, 2021 every time I power off my modem. I'm setting up this Router as an access point. I used to be able to run the firmware update and it would correct the dat...
lancewo
Apr 29, 2022Guide
Hi,
Could you show me how to do that? what is ntp?
I am currently using an xfinity cable modem and I'm setting my netgear as an access point to that I could connect to my "Readyshare" external disk drive.
Thanks so much
Apr 29, 2022Guru - Experienced User
log in through the browser and go to
Advanced tab--->administration----->ntp settings
You can change the time server. maybe yours isn't syncing for some reason.
- lancewoApr 29, 2022Guide
Under my Advanced tab --> Admin, I don't see 'NTP settings'.
I only see:
1. 'router status'
2. 'logs' (which showed a default date Sep 2021 - and it's wrong)
3. 'attached devices'
4. 'back up settings'
5. 'router update'
(see screenshot).
I clicked around and failed to find any option for me to change date/time.
Do you have any other suggestions?
Thanks much
- plemansApr 30, 2022Guru - Experienced User
I don't have that specific router to test with but thats where it is on my orbi.
