lancewo
Apr 28, 2022Guide
R6900
My R6900 Router resets the date Sep 8, 2021 every time I power off my modem. I'm setting up this Router as an access point. I used to be able to run the firmware update and it would correct the dat...
Apr 29, 2022Guru - Experienced User
log in through the browser and go to
Advanced tab--->administration----->ntp settings
You can change the time server. maybe yours isn't syncing for some reason.
lancewo
Apr 29, 2022Guide
Under my Advanced tab --> Admin, I don't see 'NTP settings'.
I only see:
1. 'router status'
2. 'logs' (which showed a default date Sep 2021 - and it's wrong)
3. 'attached devices'
4. 'back up settings'
5. 'router update'
(see screenshot).
I clicked around and failed to find any option for me to change date/time.
Do you have any other suggestions?
Thanks much
