Kendal857
Oct 09, 2022Aspirant
R6900P - No longer emails log files
Several months ago the weekly router log files stopped weekly transmission. Logged into "www.routerlogin.net" & get "connection is not secure" warning from Firefox. how do I load certificate or enable Firefox to allow email to send?
- Kendal857Aspirant
Current running Firmware Version V1.3.2.134_10.1.66
Message "Connection is not secure" when connected to "www.routerlogin.net"
see screenshot please.
Found instructions for adding security certificate but can't find the links that will enable me to do this:
NETGEAR Support ( attr(href) )
I get a security warning in my browser when I try to log in to my NETGEAR or Orbi router; what do I do?
- Launch Firefox and visit www.routerlogin.net ( attr(href) ) or www.orbilogin.net ( attr(href) ).
A security warning displays. - Click Advanced > View Certificate.
- Select Details > Export.
- Navigate to a convenient location and click Save.
- Navigate to the folder where you saved the certificate and double-click the file.
- Click Install Certificate.
An installation window displays. - Click Next.
- Make sure that the Permanently store this exception option is selected.
- Click Browse > Trusted Root Certification Authorities.
- Click OK > Next > Finish.
- Follow the prompts to install the certificate.
Note: If you enter your router’s IP address instead of www.routerlogin.net ( attr(href) ) or www.orbilogin.net ( attr(href) ), Mozilla Firefox still displays a warning message because the certificate you installed only corresponds to the domain name.
You can ignore the certificate warnings in the browser. The connection is only between the browser and the routers web page. You can use HTTP and access the routers web page.
If you changed nothing on the router in regards to emails being sent, then possible there is a problem at the Email service provider end. If you use Google they stopped supporting open email accounts with out two factor authenication and you have to use a Google generated PW with the google email account on the router. https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Enable-Email-Logging-and-Router-Reboots/m-p/2231485?search-action-id=293435612696&search-result-uid=2231485
- Kendal857Aspirant
I appreciate your fast response !
Yes I understand that this is a local connection between the browser and the router (R6900P) & yes I do access the router tools page after I log in as admin (http://www.routerlogin.net/start.htm) but when I utilize the commands: Advanced; Administration; Logs; Send Log
the log refreshes but an email is never received. I am using my ISP's (Optimum) email (so no issue with anything Gmail) and have no issue using this browser to log into the optimum web mail URL.
Something is interfering with the instruction to send the log email. What I see is that Firefox is flagging this connection as "Connection not secure" & I am working on a hunch that because their is no security certificate on file for this site that Firefox is blocking some aspects of this connection to protect me. I do not find the links that Netgear identifies in the FAQ I cited previously that would allow me to find, save & load this certificate to clear the Firefox issue & then this hopefully would allow the email log to transmit.
- KitsapMaster
Kendal857 wrote:I appreciate your fast response !
On the subject of your router sending logs via e-mail. Firefox has nothing to do with your router sending an e-mail.
On the Advanced -> Security -> E-mail page you have several options for configuring the outgoing e-mail. Have you selected the appropriate port number for the SMTP outgoing e-mail server?
Do you know if your ISP mail server requires authentication?
See attached.
