amf12
Jun 18, 2022Aspirant
R6900P 5ghz is fine, 2.4ghz will not show..
I've had this router for a while and have never had issues with it. I have a smart home set up with multiple devices that require the 2.4ghz frequency. Recently, only the 5ghz band has allowed anythi...
Kitsap
Jun 18, 2022Master
First question. Do you have the 2.4 GHz band and the 5 GHz band set with different SSID's? If not, suggest you name the 5 GHz band with xxxx_5g where xxxx is the SSID for your 2.4 GHz band.
On the group of LED indicators on the front, do both the 2.4 GHz and 5GHz show as constant or blinking white?
The attached page snip is from page 12 of the user manual. The manual is available in the Downloads section above. Review the description for the 2.4 GHz band.
