Keukasmallie
Jan 25, 2022Aspirant
R6900P can't find my own network on internet after initial set up
I followed the set up procedure, found NETGEAR51 on my list of networks, but I can't find my own network to log on to. I've tried Netgear Support and been disconected three times ffrom whatever coun...
Keukasmallie
When I was on the NETGEAR51 network I looked for my own network, ColonialC, but it wasn't listed in the list of other networks. I then selected Other and typed in ColonialC and the password. I received a message that ColonialC couldn't be found....? I don't want to be on NETGEAR51, I want to be on the network I've used for years and have shared with my family.
Jan 25, 2022Guru - Experienced User
so you can change the routers ssid (name) to match your old network.
When you replace the routers, the other device isnt' going to be broadcasting.
- KeukasmallieJan 25, 2022Aspirant
Thanks!
