Beam467
Nov 05, 2020Aspirant
R6900p constantly having to restart
Router streams 5 tvs at once with zero issues but ipads and laptop continue to have issues saying not internet even when connected. Reset the router daily to correct the problem. Just started about 2 ...
Nov 12, 2020Guru - Experienced User
Beam467
Nov 12, 2020Aspirant
So I see what u are saying, however I have nothing else running on the M1. It is wired in straight to the 6900 and does not even show up as a "wifi" option to sign onto because I have it set to the modem only option. An I missing something?
- plemansNov 12, 2020Guru - Experienced User
Have you tried it with the M1 in router mode and the r6900P in access point mode?
