cluelessoldman
Sep 08, 2022Aspirant
R6900P doesn’t have Coax
I’m trying to setup r6900p but it does not have a coax cable input. The nighthawk setup app keeps asking me to connect via Ethernet but I don’t have a household Ethernet port. Did I purchase the wrong...
- Sep 08, 2022
https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
cluelessoldman wrote:
I have Xfinity cable and no modem. I think the issue is that my (current)C6300 netgear router may also act as a modem. So I may not have purchased correctly. Do you think I can keep the r6900p and just put a modem in front of it? Thanks for the reply I appreciate it!
Kitsap
Sep 08, 2022Master
Someone ought to ask the question, why did cluelessoldman replace the C6300 in the first place?
cluelessoldman
Sep 09, 2022Aspirant
I was relaxing it because it seemed like my signal was decreasing over time, like the range seemed to be decreasing. Also I have had this router for more than a few years now, I figured a new and better one would work. The associates at Best Buy suggested this router, of course it now seems I shouldn’t have listened to them!!! Thx for replying though I do appreciate it.
- michaelkenwardSep 09, 2022Guru - Experienced User
The associates at Best Buy suggested this router, of course it now seems I shouldn’t have listened to them!!!Yup. They sold you something that is little better than the thing you already own.
But there is nothing stopping you from getting a more capable router and using that behind your current modem/router.
