clubmgr
Apr 16, 2022Aspirant
R6900P Firmware Upgrade Order
My R6900P router currently has firmware version V1.3.2.134 Both the Nighthawk app and the NetGear Genie app report that the firmware is up to date. However, the NetGear support page lists V1.3.3...
Apr 16, 2022Guru - Experienced User
Manual update is the method I usually recommend. Especially if you can do it hardwired.
You should be able to jump all the way to the latest version (.148) without issues
clubmgr
Thanks, I'll give it a shot.
- FURRYe38Apr 16, 2022Guru - Experienced User
- clubmgrApr 16, 2022AspirantThanks, I know how to do it, was just wondering if it was ok to do it. Didn’t know if I could go from 1.3.2 to 1.3.3
- plemansApr 16, 2022Guru - Experienced Usershould be able to. Its pretty rare to have to go in a stepped system. Only usually happens if they have to extend the firmware partition. And that doesn't happen often.
