justin_esta's avatar
Apr 20, 2018
R6900P. Nighthawk AC1900 Smart WiFi MuMimo
Help needed, I woke up to find out that my fully functioning wireless router has stopped working. The power light remains amber and no other color. It includes two other white LED buttons on Guest Wi...
  • michaelkenward's avatar
    michaelkenward
    May 05, 2018
    Did you try tftp?
    I'll repeat what I said before:
    How to upload firmware to a NETGEAR router using TFTP | Answer | NETGEAR Support
    That is a bit out of date in that it does not tell you that Windows has a TFTP function built in, you just have to enable it.
    • Control Panel
    • Programs and Features
    • Turn Windows features on or off
    • TFTP client - enable
    That's probably easier than retrieving software from a website.
