xraphael75's avatar
xraphael75
R6900P Nighthawk constant wifi disconnects
I have an R6900P Nighthawk router with firmware version V1.3.3.154_10.1.86 and my devices constantly disconnect
throughout the day when connected to the 5G wifi network. The 2.4 GHz network doesn't appear to have an issue. I found this thread where someone else had the exact same issue, and he never received an answer:
https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/R6900P-random-disconnect/td-p/2160995
I tried the few things that were suggested to him with the same results. My 5G wireless settings:
channel: 48
Mode: up to 1300 Mbps
Fragmentation Length: 2346
CTS/RTS Threshold: 2347
preamble mode: Long Preamble
implicit beamforming, airtime fairness, and mu-mimo are all checked.
I have a wifi analyzer on my phone, and it indicates a very strong signal. It's usually at -40 dBm, which is better than pretty much any other wifi network I try to connect to, so it's not the signal strength that's causing the disconnects.
Has anyone found a fix for this?
    channel: 48
    What is the brand name and model number of the modem/gateway/ONT that is connected upstream of your router?
    Make sure you have good quality Ethernet cables between your devices.  Cat 6 is recommended.
    Based on the Wi-Fi analyzer on your phone, do you have Wi-Fi neighbors or live in an environment with lots of radio frequency signals?
    • xraphael75's avatar
      xraphael75
      SMART/RG SR400ac
      They are either cat5 or 6
      On the 5G network I see 10 other networks. My R6900P is the only one on channel 48, and the only one on 5240MHz Frequency, so it seems that nothing else should be interfering with it.
      • Kitsap's avatar
        Kitsap
        Master
        SMART/RG SR400ac
        Basically a repeat question, what is the brand name and model number of the modem/gateway/ONT that is connected upstream that provides your internet connection?  The SMART/RG SR400ac is not a modem/gateway/ONT.  What is between the SMART/RG SR400ac and the internet?  Any more devices that also are a router?
        The SMART/RG SR400ac is a Wi-Fi router similar to your R6900P.  Your configuration has them cascaded in series so they are in conflict with each other full time.  The condition is known as double NAT and it is the first thing your need to resolve.
        For background check here:  https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
        You can usually get by with Cat 5e Ethernet cables.  Your Cat 5 Ethernet cables should be replaced with Cat 6.
